Float invalid operation due to negative temperature
fyp2d_dem_model_2024-11-11T163501.890050.zip (322.0 KB)
Why is there a “float invalid operation” ? And any ideas on how to solve convergence problems ?
We get better debug information on Linux:
Error: Unexpected solver message:
Backtrace for this error:
#0 calc_k_g_mod_MOD_calc_default_kg
        at calc_k_g.f:76
#1 calc_k_g_mod_MOD_calc_k_g
        at calc_k_g.f:32
#2 transport_prop_mod_MOD_transport_prop
        at transport_prop.f:65
#3 calc_coeff_mod_MOD_calc_coeff
        at calc_coeff.f:344
#4 calc_coeff_mod_MOD_calc_coeff_all
        at calc_coeff.f:272
#5 step_MOD_time_step_init
        at time_step.f:93
#6 run_fluid
        at mfix.f:186
#7 run_mfix
        at mfix.f:145
#8 main_MOD_run_mfix0
        at main.f:85
Using the gdb debugger:
#0  0x00007f067f5dd82f in calc_k_g_mod::calc_default_kg ()
at mfix/src/model/calc_k_g.f:76
76	            K_G(IJK) = 6.02D-5*SQRT(T_G(IJK)/300.D0)
(gdb) print(ijk)
$1 = 159
(gdb) print(t_g(ijk))
$2 = -534.61044673739423
The temperature has gone negative in this cell.
I’m not sure why this has happened or why it was not trapped as non-physical before the SQRT call.
Thank you for your help. I’ll try to figure out why.
A few things you can try:
  1. Use Implicit Euler instead of Crank Nicholson for time integration
  2. Reducer the size of the cells in the y-direction (current aspect ratio is 10)
  3. Double check pressure for IC and BCs (currently close to 10 atm)
  4. Use ideal gas density (incompressible gas is not appropriate here)
Sorry for the late reply. Thank you for the suggestions. :smile:
