When I add reactions on Linux, it builds solver successfully and runs with the following errors. But I didn’t meet the problem when I do the same thing on Windows.
BFD: Dwarf Error: found dwarf version ‘5’, this reader only handles version 2, 3 and 4 information.
==== backtrace (tid: 23007) ====
0 0x0000000000050b35 ucs_debug_print_backtrace() ???:0
1 0x00000000000948b8 usr_MOD_calc_k21_hikita() ???:0
2 0x000000000009ab30 usr_rates() ???:0
3 0x000000000029ed89 rrates0() ???:0
4 0x00000000000baa7c __calc_coeff_mod_MOD_calc_rrate() ???:0
5 0x00000000000bacba __calc_coeff_mod_MOD_calc_coeff_all() ???:0
6 0x0000000000320176 _step_MOD_time_step_init() ???:0
7 0x0000000000269426 run_mfix() ???:0
8 0x00000000000832b5 __main_MOD_run_mfix0() ???:0
9 0x0000000000076fcd f2py_rout_mfixsolver_main_run_mfix0() mfixsolvermodule.c:0
10 0x000000000017f88c _PyObject_FastCallKeywords() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:199
11 0x00000000001802d1 call_function() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:4619
12 0x00000000001c7602 _PyEval_EvalFrameDefault() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:3093
13 0x0000000000138d17 PyEval_EvalFrameEx() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:547
14 0x0000000000138d17 _PyFunction_FastCallKeywords() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:408
15 0x00000000001800c5 call_function() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:4616
16 0x00000000001c3381 _PyEval_EvalFrameDefault() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:3110
17 0x0000000000138d17 PyEval_EvalFrameEx() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:547
18 0x0000000000138d17 _PyFunction_FastCallKeywords() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:408
19 0x00000000001800c5 call_function() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:4616
20 0x00000000001c3381 _PyEval_EvalFrameDefault() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:3110
21 0x000000000011a0a6 PyEval_EvalFrameEx() /tmp/build/80754af9/python_1627392990942/work/Python/ceval.c:547
22 0x000000000011a0a6 _PyFunction_FastCallDict() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:322
23 0x000000000011a0a6 _PyObject_FastCallDict() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:98
24 0x000000000012f041 _PyObject_Call_Prepend() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:906
25 0x000000000012f041 method_call() /tmp/build/80754af9/python_1627392990942/work/Objects/classobject.c:309
26 0x000000000011a7b6 PyObject_Call() /tmp/build/80754af9/python_1627392990942/work/Objects/call.c:245
27 0x0000000000221a23 t_bootstrap() /tmp/build/80754af9/python_1627392990942/work/Modules/_threadmodule.c:994
28 0x00000000001daa77 pythread_wrapper() /tmp/build/80754af9/python_1627392990942/work/Python/thread_pthread.h:174
29 0x0000000000007dd5 start_thread() pthread_create.c:0
30 0x00000000000fdead __clone() ???:0
Backtrace for this error:
** Something went wrong while running addr2line. **
** Falling back to a simpler backtrace scheme. **
#29 0x7fc5274972d2
#30 0x7fc527497a0e
#31 0x7fc57b5605cf
#32 0x7fc527ffc8b8
#33 0x7fc528002b2f
#34 0x7fc528206d88
#35 0x7fc528022a7b
#36 0x7fc528022cb9
#37 0x7fc528288175
#38 0x7fc5281d1425
#39 0x7fc527feb2b4
#40 0x7fc527fdefcc
#41 0x5620e9e5f88b
#42 0x5620e9e602d0
#43 0x5620e9ea7601
#44 0x5620e9e18d16
#45 0x5620e9e600c4
#46 0x5620e9ea3380
#47 0x5620e9e18d16
#48 0x5620e9e600c4
#49 0x5620e9ea3380
#50 0x5620e9dfa0a5
#51 0x5620e9e0f040
#52 0x5620e9dfa7b5
#53 0x5620e9f01a22
#54 0x5620e9ebaa76
#55 0x7fc57b558dd4
#56 0x7fc57b281eac
#57 0xffffffffffffffff
/ncsfs02/bychen/case/cokedrum/mfixsolver: line 3: 22997 Floating point exception(core dumped) env LD_PRELOAD=/opt/openmpi-4.1.2/lib/libmpi.so LD_LIBRARY_PATH=${LD_LIBRARY_PATH:+$LD_LIBRARY_PATH:}"/ncsfs02/bychen/anaconda3-5.3.0/envs/mfix-21.1.4/lib/libpython3.7m.so" PYTHONPATH="/ncsfs02/bychen/case/cokedrum":"":${PYTHONPATH:+:$PYTHONPATH} /ncsfs02/bychen/anaconda3-5.3.0/envs/mfix-21.1.4/bin/python3.7 -m mfixgui.pymfix “$@”
When I put a successful case from Windows into Linux, I get the following error:
Thanks for your help!
case 1.zip (4.1 MB)
case2.zip (5.4 MB)
