Hello,everyone.
I set the liquid flow rate at the entrance, but in the calculation, the liquid phase did not work and ellipsoidal particles fell freely. Can teachers help me see what the reason is? Thanks for your help!
LSFB-1.zip (1.2 MB)
What do you mean by “the liquid phase did not work”?
You are saving the cell data every 1 second and you have not reached that time yet so you are only looking at the initial condition. Set the write interval to say 0.01 sec so you can visualize the flow field at a faster rate.
Is your inlet velocity above minimum fluidization?
Thank you for your help!@jeff.dietiker
Inlet velocity is higher than minimum fluidization velocity,perhaps it was caused by my setting to save grid data for too long.
