Hey all,
Are there any help resources for generating MPI-compatible particle input files?
I have a particle initialization file that works in serial (see attached) but I’m struggling to parallelize it. The source code seems to indicate that I need separate input files for each processor, numbered by processor ID [from WRITE(lFILENAME,’(“particle_input_”,I4.4,".dat")’) myPE]. I’m not sure how to determine which processor ID is associated with each region of the domain, and I imagine this order will change somewhat each run, depending on how the scheduler allocates nodes and processors to the simulation.
Is it not possible to initialize all particles on the root process and then broadcast particles to their respective processors?
Let me know if you have any advice or thoughts.
particle_input.zip (48.4 KB)
