how i can track single particle trajectory in dem?
There are a variety of ways to accomplish this.
- Write a UDF to save the data for a particular particle (based on the global ID).
- Save the data you want for the particles along with the global IDs to output files then post-process them to obtain the data you want.
- Probably the simplest is to make a second phase with a slight diameter or density difference (DEM phases have to be distinct) and only save the data for that phase in a separate output file.
thanks JMuser
i will use the third option
@jmusser kindly explain the third way you mentioned above?
What Mr. JMusser meant is to create a second phase this could be done as follow:
1-create a particle with a diameter differ from the one of your interest with same density.
2- create a particle with the same diameter but with a different density.
This brings another topic in my mind when we use coarse- graining method one could model the particles by using a constant number of particle for the created parcel for all PSD, other could use the ratio of the particles to create a representative parcels with same ratio.
@mhdabiker I only want to track single particle trajectory among many. How is it possible?
Please see the three options above.
A fourth option (more complicated) would be to enable user scalar tracking (Solids>DEM, Advanced pane), initialize the scalar to one for the particle you want to track, zero for all others (done in a udf) , and save the DES user scalar in the vtp files. In Paraview use a threshold to isolate the particle with a scalar value of one.
Hello, Sir! May I ask that why I cant find this box: enable user scalar tracking in (Solids>DEM, Advanced pane). My Mfix edition is 25.1.2, could you help please?
A) This thread is 7 years old, probably best to start a new thread
B) “Enable user scalar tracking” is in the model setup pane, not Solids->DEM
C) Please attach files when looking for help.
