Is there a way to achieve diagonal air intake like the one shown in the figure below?![]()
This should be easy to create with an STL editor such as OpenSCAD or possibly using Procedural STL inside of MFiX itself. What have you tried? How did you produce the image above?
I want to achieve this using point sources. I created a region to add point sources, but this region doesn’t seem to be rotatable — it can only be aligned parallel to an axis.
This looks like a point source setting. I am suggesting you apply a Mass inlet BC and set the velocity component along the inlet plane, not the flow rate.
Please attach your case files!
