Hello @jeff.dietiker @cgw .
I am working on validating the pressure drop in a lab setup with a homogeneously mixed bed of binary particles, using simulations conducted in a scaled-down geometry. The packed bed void fraction in the experiments is 0.36. How to seed the particles at a specific void fraction.
I manually performed all the calculations to create a homogeneously mixed bed of binary particles, but the resulting bed was slightly densely packed and had a void fraction of 0.34. How can I generate a bed with a specific void fraction?
I conducted several runs by adjusting the des_epg_clip value. Modifying this parameter alters the local void fraction in each cell, which in turn affects the pressure within the cells. How can I adjust this value to achieve the same bulk void fraction as observed in the experiments? any help would be apprieciated. Thanks in advance. I would appreciate it if you could respond at your earliest convenience.
