Hey guys, can I change the length unit of MFiX?
The diameter of particles I am analyzing are are between 1 and 5 microns . However, the current unit of length is meters. I don’t know if the particle size is too small to casue divide-by-zero errors.
You could use CGS units, but CGS units are not supported in the GUI and I do no think this would be the cause of a division by zero. What solids model are you using? I would not recommend using DEM with such small particles, it will be too slow.
Also, double-precision variables have a range of about 10e-300 so I doubt underflow will be an issue. However as Jeff pointed out, you may find that the models run extremely slowly. (If you are seeing zero-division errors please post the details here)
