I want to input different particle-wall mechanical properties on different walls in MFix-DEM for the same channel. Since the front and rear wall are of different material, I should be using different particle-wall values.
If the walls are considered same in DEM.
How can I separate the walls to input different particle-wall mechanical properties separately?
This is not natively supported, it is assumed all walls behave the same. If you want to modify the code, you can start by studying model/des/calc_collision_wall_mod.f and model/check_data/check_solids_dem.f.
You may need to modify more files depending on how you want to implement it. If you just want a quick ad hoc implementation, where you overwrite existing variables, this may be sufficient. If you want a robust implementation, then you need to introduce new variables and new keywords. This will require some time investment so you get familiar with the code. The two files I mentioned is a starting point, then you need to decide how you want to implement and browse through the code.
