Hello,everyone!
I found the formula for calculating the drag force in the sq_drag. f file. To output the value of the drag force on particles, what code needs to be added to the. f file to output it?
Thank you for your reply! @cgw
LDgA is the drag coefficient. If I want to output the calculated value of drag, which (. f) file do I need to add code to? Is it adding code in the (drag_gs_des1. f) file?
