Hello developers,
My simulations stopped without reaching the set time, and I found that it was due to the wall time setting by reviewing the related issues.
I have read about similar problems.
Time issue during running the simulation (REQUESTED CPU TIME LIMIT REACHED) - MFiX / How to - NETL Flow Science Software Support (doe.gov)
Restarting Mfix batch solver - MFiX - NETL Flow Science Software Support (doe.gov)
But I still have some questions.
1.Do I just need to change the run_type from “new” to “restart_1” in the .mfx file? The original case has “enable max wall time” checked, do I need to turn it off by some modification before restarting?
2.What command should be set in the script file to make it possible to restart the calculation for the modified case?
Looking forward to any possible replies, thanks!
