Dear Expert,
could you please tell me, what steps I have to follow to run the simulation in the multiple-node ( in HPC)?
I installed the Mfix software in HPC but the problem is: that it is running only one node could you suggest if I want to run this simulation in multiple nodes or cores then what steps do I have to consider?
and any other steps that we need to follow to install in the HPC, please suggest.
This simulation is running in HPC in master nodes while I want to run this in parallel nodes (Parallel computing) so how much core or MPI requirement please suggest?
I run one simulation, but one error is coming “Attempt to use a texture buffer exceeding your hardware’s limits. This can happen when trying to color by cell data with a large dataset. Hardware limit is 65536 values while 114400 was requested.
2023-11-07 16:00:47.383 ( 269.218s) [ 26D46740] vtkTextureObject.cxx:1025 ERR| vtkTextureObject (0x55eff2a02c10): Attempt to use a texture buffer exceeding your hardware’s limits. This can happen when trying to color by cell data with a large dataset. Hardware limit is 65536 values while 114400 was requested.”
