How to set the outlet BC like the picture below?
hello everyone,
I have met a problem, i draw a geometry model in solidworks, and there are 2 outlets in the model, can anyone tell me how to set the outlet2 BC in the mfix-dem?
the .sldprt and .stl files are uploaded below.
str_outlet_1.STL (4.0 KB)
sldprt_file.zip (103.1 KB)
You can either extend the out2 boundary all the way to the top, or create a rectangular block of wall cells
that go down from the out to the out2 plane, where you would define a pressure outlet BC.
tanks jeff,can you give me a specific explanation about "creat a rectangular block that go down from the out to out2 plane "? I am confused about what you’re saying.
A BC plane cannot have fluid cells on both sides of the plane. Here the out2 plane is in the middle of the fluid region (shown in red below). We must add a block of No-Slip Wall cells above the plane (shown in green below):
