How to solve floating-point exception?
Hello, everyone
I want to use pic module to simulate the gasification process of sludge and biomass. The solver was built successfully, but a strange floating-point exception error occurred when I run MFIX simulation. I didn’t know if it is caused by mesh quality, because this error did not occur before I switched to a cylindrical boiler.
1
Thanks for your help!
lab_boiler_2023-05-18T203944.349095.zip (377.8 KB)
I am not able to reproduce the same error you showed but I got an error due to re-indexing. Please turn off re-indexing. I am not sure what you are trying to do in usr1.f (you are accessing particle and cell data outside of a particle or cell loop and what you compute is not used anywhere), and it crashes immediately in debug mode.
FWIW, I’m seeing an FPE in drag_gs.f
#0 drag_gs_mod_MOD_drag_syam_obrien
        at drag_gs.f:515
#1 des_drag_gp_mod_MOD_des_drag_gp
        at des/drag_gp_des.f:229
#0  drag_gs_mod::drag_syam_obrien (ldga=2.1348523916463698e+18,
    epg=0.022340574725662081, mug=1.8e-05, rog=2.0115915930129507e+17,
    vrel=0.00099583386699245375, dpm=0.00050000000000000001)
    at /home/cgw/mambaforge/envs/mfix-git/share/mfix/src/model/drag_gs.f:515
515	      lDgA = 0.75D0*Mug*EPg*C_DSXRE_DV(RE/V_RM)/(V_RM*DPM*DPM)
(gdb) p V_RM
$1 = 0
(gdb) p A
$2 = 1.4630210456148707e-07
(gdb) p RE
$3 = 5564475096887769
(gdb) p BB
$4 = <optimized out>
(gdb) p drag_c1*EPg**1.28D0
$5 = 0.0061649668266085915
We’re dividing by V_RM which is 0. Looking where this is computed:
   477  ! Variables which are function of EP_g
   478        DOUBLE PRECISION :: A, BB
   479  ! Ratio of settling velocity of a multiparticle system to
   480  ! that of a single particle
   481        DOUBLE PRECISION :: V_rm
   482  ! Reynolds number
   483        DOUBLE PRECISION :: RE
   484  !-----------------------------------------------
   485
   486        IF(Mug > ZERO) THEN
   487           RE = DPM*VREL*ROg/Mug
   488        ELSE
   489           RE = LARGE_NUMBER
   490        ENDIF
   491
   492        IF (RE == ZERO) THEN
   493           lDgA = ZERO
   494           RETURN
   495        ENDIF
   496
   497  ! Calculate V_rm
   498        A = EPg**4.14D0
   499        IF (EPg <= 0.85D0) THEN
   500           BB = drag_c1*EPg**1.28D0
   501        ELSE
   502          BB = EPg**drag_d1
   503        ENDIF
   504
   505        V_RM=HALF*(A-0.06D0*RE+&
   506             SQRT((3.6D-3)*RE*RE+0.12D0*RE*(2.D0*BB-A)+A*A) )
The Reynolds number 5564475096887769 is suspiciously large. And the computation of V_RM at 505 is perfectly balanced to come out to 0:
>>> HALF*(A-0.06*RE+SQRT((3.6E-3)*RE*RE+0.12*RE*(2.0*BB-A)+A*A) )
0.0
>>> BB
333868505813266.1
>>> A-0.06*RE
-333868505813266.1
Very odd!
@jeff.dietiker
Thanks for your answer,I want to calculate the Sherwood number, Prandtl Number, Reynolds Number, Nusselt Number and the heat transfer coefficient in usr1.f, which might be used to further modify my reaction model in the future. I rewrote usr.f by referring to the tutorial shared by MFIX, mfix-22.4.3\share\mfix\templates\tutorials\pic\silane_pyrolysis_3d
Could that be the cause of the error?
@cgw
Hello Charles, thanks for your suggestion, I just replied to @jeff.dietiker about usr1.f. And I calculated the Reynolds number in usr1.f. I’m not sure if it is the reason caused the error.
