HTC in TFM simulation
Hi, everyone,
When simulating heat transfer between the wall-solid phase and the wall-gas phase, the heat transfer coefficient is usually correlated with operating conditions. However, I have found that in the MFIX-TFM GUI, the transfer coefficient can only be set as a constant. Therefore, we want to know if it is possible for us to replace it with a correlation and which subroutine we should modify.
Thank you.
My guess is this can be done in bc_phi.f. Please note that this will require quite a bit of time investment on your part to learn the code structure.
Hi, Dr. Dietiker,
I apologize for my delayed response. I appreciate your prompt reply. However, I have been unable to log in to the forum these past few days. Thank you for pointing out the areas that need modification and for your kind reminder.
After studying the code, I have observed that BC_HW_PHI in the code represents the heat transfer coefficient. It appears that in the code, the heat transfer coefficient is considered a constant, indexed by the boundary item number, as displayed in the software GUI. Therefore, it seems necessary for me to define an additional function to retrieve the heat transfer coefficient.
Moreover, I would like to know if an error would occur in the GUI when attempting to calculate this coefficient using an expression, given that the GUI only allows for a constant input.
Thank you.
Yes, you will need to define a function to compute a local heat transfer coefficient. The GUI can convert simple arithmetic expressions, but it is still considered a constant value once it is passed to the solver. This is not meant to have a local or transient value.
Hi, Dr. Dietiker,
Thank you for your reply. Additionally, I would like to know whether it is feasible to impose a temperature profile along a wall or apply a heat transfer coefficient that varies along the wall when dealing with customized thermal boundary conditions.
Upon reviewing the source code, it appears that both the heat transfer coefficient and the wall temperature are set as constant values, such as bc_hw_t_g(4) = 0.0 and bc_tw_g(4) = 293.15. If I modify these constants to expressions that depend on height (or any other spatial variable), would this approach work? For instance, setting bc_hw_t_g(4) to an expression based on height to simulate a varying heat transfer coefficient along the wall.
