Implementation of constant heat flux boundary condition in DEM and CGP
Hello Developers,
I am a beginner trying to use M-Fix and I am building a CGP model with a constant heat flux applied to the front wall of my geometry to simulate solar hear flux. I have attached the files for case below. When I run the case I get this error :
Error from check_data\check_bc_walls.f:551
Error 1100: The energy equation boundary condition 10 is ill
defined for solids 1. Walls can be adiabatic or have a
specified temperature for DEM. Please correct the project settings.
Can we not use a constant heat flux BC for the solids in DEM or CGPM?? The same case works well with constant temperature BC but not for constant heat flux BC. I would really appreciate your feedback.
Regards,
Ashreet Mishra.
testflux_2022-06-15T115437.967353.zip (29.8 KB)
Hello @onlyjus @cgw @jeff.dietiker ,
I would really appreciate it if one of you could help me answer this.
Regards,
Ashreet Mishra.
DEM or CG-DEM do not support constant flux for the solids phase. It should have been disabled in the GUI.
Thank you so much for the response @jeff.dietiker. Much appreciated.
