Hello Li -
This is a floating-point exception, that is, a math error.
Here’s the offending line (496) in des_thermo_cond_mod.f
496 TERM3 = TWO*PI*(ONE-OLAP)*log((ONE-OLAP-sqrt(ONE-Rout**2))/Kn)
I added a write(*,*) statement on the previous line to report the values of OLAP, ROUT, and KN. Right before failing it prints:
OLAP= 3.1569290598721614E-002
ROUT= 1.0000000000000000
KN= -1.0024507434496799E-006
Note that Kn is negative, so the logarithm is being attempted on a negative value:
>>> print( (ONE-OLAP-sqrt(ONE-Rout**2))/Kn)
-966063.1364975298
Looking at L465 in des_thermo_cond_mod.f:
DOUBLE PRECISION FUNCTION EVAL_H_PFP(RLENS_dim,S,OLAP_dim,RP)
USE CONSTANT
USE PARAM1
IMPLICIT NONE
! Note: Function inputs dimensional quantities
DOUBLE PRECISION, intent(in) :: RLENS_dim, S, OLAP_dim, RP
! BELOW VARIABLES ARE NONDIMENSIONALIZED BY RP
DOUBLE PRECISION :: RLENS, OLAP, KN
DOUBLE PRECISION :: TERM1,TERM2,TERM3
DOUBLE PRECISION :: Rout,Rkn
DOUBLE PRECISION, PARAMETER :: TWO = 2.0D0
RLENS = RLENS_dim/RP
KN = S/RP
OLAP = OLAP_dim/RP
A debugger session with gdb (or more write statements) shows us that S is getting passed in with a negative value:
#1 0x00007fe08357376e in des_conduction::eval_h_pfp (
rlens_dim=1.0001875441682284, s=-2.0048488274173704e-08,
olap_dim=0.00063136922839164208, rp=0.019999474692573838)
One frame up the stack:
#2 0x00007fe083574486 in des_thermo_cond::des_conduction (i=394, j=420,
center_dist=0.018987945901915475, im=<optimized out>,
iijk=<optimized out>)
at /home/cgw/mfix/model/des/des_thermo_cond_mod.f:184
184 H_2 = EVAL_H_PFP(RLENS_2, S_2, OLAP_2,MAX_RAD)*MAX_RAD*k_gas
and a few lines further up in the same file:
163 RATIO = (OLAP_actual + DES_MIN_COND_DIST) / MAX_RAD
164 S_1 = (MAX_RAD*MAX_RAD*(RATIO-0.5D0*RATIO*RATIO)/&
165 &(CENTER_DIST_CORR-DES_MIN_COND_DIST)) - OLAP_1
166 S_2 = DES_MIN_COND_DIST - S_1
This is where the negative value is coming in - S_1 is greater than DES_MIN_COND_DIST, so S_2 is negative. I suppose MFiX should have a check for this, we will take a look at the solver code and see if more checks are needed.
But DES_MIN_COND_DIST is an MFiX keyword so you could try setting it to a higher value, to keep S_2 from going negative. However if you set it too high, S_1 could become negative.
It looks like the default value for DES_MIN_COND_DIST is 1E-6. This is not well-documented, see check_data/check_solids_dem.f lines 165
I suggest you try adjusting DES_MIN_COND_DIST and let me know if it helps.
