I just want to know if JKR model is available in MFiX-DEM ?
If not, can I implement it.
Kindly let me know if there is any tutorial on adhesion modeling (VDW or JKR).
I look forward to hearing from you
Thanks, and Best Regards,
Sincerely,
Debashis
The JKR model is not present in MFiX. I am not aware of any tutorials on adhesion modeling, although others may be able to suggest some examples for you.
There is an example of VDW in mfix/legacy_tests/cohesionVdwAsperities. This is a legacy test using CGS units and it may not work if loaded from the GUI. You may have to run it from command line.
The GUI will convert this from CGS to SI and since there are no UDFs it runs fine.
