Hi, everyone,
I am encountering an issue when attempting to submit a job after compiling the MFiX solver using the SMP. The command I used for submission is as follows:
env OMP_NUM_THREADS=10 ./mfixsolver_smp -f mfix.dat
However, upon execution, I receive an error indicating that there is an inconsistency between the number of requested processors and the domain decomposition, which leads to the termination of the program.
The specific error message is as follows:
Number of SMP threads: 10
Using /home/test/test/test4_t/mfixsolver_smp.so
MFiX (23.4.1) simulation on host: pvecluster
Run name: test_TFM Time: 14:42 Date: 1- 3-2025
Project version: 20
________________________________________________________________________
MESSAGE from open_files.f:373
This is a rectangular geometry simulation.
Mesh generation will be performed.
No mesh file will be written, only the [RUN_NAME]_boundary.vtk file will be written.
ERROR from check_data/check_dmp_prereqs.f:131
Error 1003: The number of requested processors is inconsistent
with the domain decomposition, (NODESi * NODESj * NODESk).
These numbers must match.
Number of requested processes: 1
Domain decomposition : 10
Program Terminated.
ERROR STOP 1
