Dear All,
The simulation lasts about 10 hours and then stopped unexpected with errors as follows. The other parts are normal.
Timestep walltime, fluid solver: 0.928 s
PIC NITs: 1 Total PIP: 667
Timestep walltime, PIC solver: 0.031 s
=============== REQUESTED CPU TIME LIMIT REACHED =
Batch Wall Time: 2.00 days
Elapsed Wall Time: 2.00 days
Term Buffer: 180.00 s
C:\Users\juu.conda\envs\mfix-21.2\lib\site-packages\mfixgui\pymfix_webserver.py:44: UserWarning: The ‘environ[‘werkzeug.server.shutdown’]’ function is deprecated and will be removed in Werkzeug 2.1.
shutdown() # will finish current request, then shutdown
MFiX process has stopped
t= 2.315513 Wrote .RES;
DES.RES;
Total CPU used = 1.998 days
Total CPU IO used = 25.30 s
Total wall time used = 9.824 h
function ‘_gfortran_set_options’ not found
(mfix-21.2) C:\Users\juu\Documents\mps_simulation\builtin_sphere1>endlocal
