The simulation is pure granular flow of solid particles.
I am calculating the mass flow rate at the plane shown below using mass flow rate monitoring in Mfix dem.
I got average mass flow rate of 0.001002kg/s at steady state from 0.2s to 0.8s.
In paraview, I created the same plane and I counted the particles at 0.8s by counting the particle IDs. Basically I removed the duplicate particleIDs and counted the remaining. I got 5785 number of particleIDs which passed through the plane upto 0.8s. The total mass calculated for these number of particles is 0.000595kg. Then mass flow rate is calculated and is found as 0.000744kg/s. The calculated mass flow rate by counting the number of particles passed through this plane has significant difference from the average mass flow rate monitoring at steady state.
I wonder which is the accurate method to calculate mass flow rate and why there is significant difference?
