Hello everyone,
I’m currently working with MFIX-TFM to simulate a bubbling fluidized bed, and I’ve run into a challenge that I’m hoping the community can help me understand.
Using the tutorial case “fluid_bed_tfm_2d,” I conducted a mesh independence study where only the mesh size was varied while all other settings remained constant. According to the rule of thumb for achieving mesh independence in TFM simulations, the mesh size should be smaller than ten times the particle diameter. In my tests, I used meshes sized at 10x, 5x, and 2.5x the particle diameter.
However, I’ve encountered an issue where the computed flow fields appear inconsistent as the mesh size changes. This is different from what we typically observe in single-phase fluid simulations, where refining the mesh generally leads to a more consistent flow field. For TFM simulations, it seems decreasing the mesh size does not necessarily lead to a converging solution for the flow field, which is puzzling to me.
Fig. 10x particle diameter
Fig. 5x particle diameter
Fig. 2.5x particle diameter
My confusion lies in understanding why, for TFM simulations, refining the mesh does not yield a consistent flow field as expected. Although I have reviewed some literature over the past several days, I have yet to find papers that directly discuss this issue.
Could anyone provide an explanation for this phenomenon or point me towards relevant papers that discuss this specific challenge? Any insights would be greatly appreciated!
Thank you in advance for your help.
Best regards,
