Even if nrr>0, in the vtk section the ReactionRates boxes to click and to add their name are not appearing. It worked with mfix-20 version.
I can open a project I setup with mfix-20 and see them with mfix21-3, but when setting up the project in mfix-21-3 I don’t have them available.
Thanks for the help.
Eric
Hi Eric,
We will fix this for 21.3.1. In the meantime here is a little trick to bypass the issue:
- Go to the Advanced pane. Click the “+” sign above the keyword table.
- Check the "Include GUI keywords at the bottom left. In the search bar, start typing vtk_rrate. The keyword should appear below the search bar, select it.
- Enter the vtk (region) and rate index. For example enter VTK=2 and rate=1 to set vtk_rrate(2,1). Click the lock icon, next to the greyed out “Update key” button. Read the warning and click OK.
- Adjust the value of the keyword. Check the box next to value. It will change from False to True. Click the “Update key” button and close the keyword browser.
- Option 1: Close the keyword browser. Go back to the Output > VTK > Reaction tab. You should see the nrr rates and labels now.
Option 2: Click the “Locate control” from the keyboard browser. It should take you to the Output > VTK > Reaction tab.
