MFIX 25.3 simulation with Cyclic BC fails on HPC but runs on local computer
The simulation attached runs well on my laptop but on HPC (both HPC and my laptop using MFIX-25.3), it fails right at the start after some angry messages:
Beginning DEM settling period: 1 steps.
DEM settling period complete.
t= 0.000000 Wrote SPx: 1,2,3,4,A,B; .RES; DES.RES;
Velocity exceeds limit: 50000.
in cell: I = 2 J = 2 K = 1
Epg = 0.48603 Ug = 0.27423E+06 Vg = 22289. Wg = 0.0000
Recovered: Dt= 0.90000E-03 :slight_smile:
Epg = 0.48603 Ug = 0.14551E+06 Vg = 18478. Wg = 0.0000
Recovered: Dt= 0.81000E-03 :slight_smile:
I tried to run and compile in serial and it still fails. I am out of options there.. Thanks for the help
bedload_water_only.mfx (17.5 KB)
particle_input.csv (272.4 KB)
Not sure, I cannot reproduce on our HPC. It seems to run fine (currently at time=0.20s). Can you try the batch solver and/or a different fortran compiler?
#Yodamode. I am already compiling with build_mfixsolver --batch -j --dmp. I ll try another compiler then.
I have used another cluster with very different compilers and can get the case to run in serial or with a small decomposition of the domain in DMP. Once I add all the subroutines I needed for the “actual” case, it does not run though (yet it does run perfectly on my laptop :frowning: )
Make sure you build in debug mode when you have custom code.
