Improvements/new capabilities
- Add mass, volume, and kinetic energy entries to Lagrangian monitors (exa/mfix!1456)
- Implement mixture fluid molecular viscosity (exa/mfix!1410)
- Improve PIC2DEM memory usage (exa/mfix!1138)
- Particle induced (pseudo) turbulent viscosity - Subramaniam (exa/mfix!1443)
- Tangential history (exa/mfix!1245)
- Support for particle induced turbulence viscosity - Sato (exa/mfix!1429)
- Add amrex::GeometryData to ComputeTxfrCoeff struct (exa/mfix!1423)
Bug fixes
- Return nullptr if not allocated (exa/mfix!1458)
- Define BC Rec for volume fraction and use in MAC velocities routine (exa/mfix!1444)
- Pull average DEM particle properties from BC settings (exa/mfix!1442)
- Solids inflow overshot input settings (exa/mfix!1440)
- Zero out coupling forces on particles inside a porous media region. (exa/mfix!1437)
- Create directory for monitors if path different than current directory (exa/mfix!1438)
- Fix where porous media volume fraction is imposed (exa/mfix!1436)
- Fix under/overflow of solids volume for inflow (exa/mfix!1435)
- Fix logic for periodic BCs with PIC (exa/mfix!1434)
- Fix the normal in eb hopper code (exa/mfix!1432)
- Follow on to MR 1425. Fix computation of average time per step (exa/mfix!1427)
- Fix hypre variables (exa/mfix!1426)
Code cleanup
- Remove debug print statement (exa/mfix!1464)
- Add comments and do ground for next commit (exa/mfix!1460)
- Remove redundant species update (exa/mfix!1459)
- Remove particles mass variable (exa/mfix!1455)
- Refactor step data (exa/mfix!1453)
- Remove volume from particles’ variables (exa/mfix!1451)
- Remove option to include drag in nodal projection (exa/mfix!1452)
- Regrid routine (exa/mfix!1446)
- Remove unused routines (exa/mfix!1441)
- Unify the MAC and Nodal projection RHS calculations (exa/mfix!1428)
- Use make invalid to flag particles to remove (exa/mfix!1431)
- Remove pic and dem restart conversions (exa/mfix!1430)
- Split steady-state out of transient update (exa/mfix!1425)
- Diffusion operator (exa/mfix!1422)
CI and test changes
- Fix ctests (exa/mfix!1454)
- Fix CTests – addendum to !1444 (exa/mfix!1445)
Subproject updates
- Change csg-eb submodule url from relative to absolute (exa/mfix!1433)
Tools updates and fixes
- none
