I am new to MFiX, and I was wondering if there are any tutorials, examples, etc. that utilize the basic MFiX-RAD plug in.
Thank you!
Thank you!
Hi James, welcome to the MFiX forum.
Here’s slides from the author’s presentation at the 2016 MFiX workshop: Radiative Heat Transfer
I see that the code at MFIX-RAD / Code / [88d4b9] hasn’t been touched since 2016. I downloaded it and tried compiling it with current MFiX, it mostly builds except that the usr_rates.f
file depends on some specific reaction names and species being defined. There’s no mfix.dat
or species.inc
present in this repo so symbols like Ash1
and Char_to_Char
are not defined. But you probably want to modify usr_rates.f
anyhow to match your simulation. (Also note that in the next version of MFiX the implementation of user-specified reaction rates will be a little bit simpler).
After deleting usr_rates.f
and trying again I get this error:
/tmp/mfix-rad-code/usr0.f:65:37:
65 | CALL FLUSH_ERR_MSG(ABORT=.TRUE.)
| 1
Error: Keyword argument requires explicit interface for procedure ‘flush_err_msg’ at (1)
This is because the error handling code has changed a bit since 2016, and FLUSH_ERR_MSG
is in fact no longer used. But it would be pretty straightforward to update this code to use the newer error-handling conventions.
Let us know if you use this package, especially if you get any interesting results.
Thank you Charles for looking into this, and providing the author’s presentation at the MFiX workshop. I also appreciate you for compiling the code with the current version of MFiX. I will certainly keep in touch as I experiment with this package.
Thank you again for your help and assistance - I greatly appreciate it.
Kind regards,
James
