Hello everyone!
I want to try a simple reaction with mfix.(C+O2=CO2)I have two problems.
First,I can’t find solid carbon in the species database, and I can’t find the carbon a1-a7 when I add the new species, so I borrowed the carbon a1-a7 from some other people’s cases on the forum.It’s OK.
Second,Since this is a heterogeneous reaction, I set the reaction rate in usr_rates_des.f imitating the case in the user manual. But I didn’t see any CO2 generation. I increased the temperature, but it was still useless.
So I want to ask what went wrong.
Attach my case.
thank you very much!
----Li
c_2021-10-20T141303.889123.zip (777.3 KB)
Hi Li -
Carbon is in the species database (“Burcat”) in a few different forms
It’s also in there as ‘diamond’ but searching for ‘carbon’ doesn’t find that
Finally, amorphous carbon / lampblack is present as well but is not considered a solid. If you click the ‘G’ and ‘L’ buttons next to ‘Phase’ the search will be expanded to all phases.
Since C is a variable used in MFiX, the symbol C cannot be used directly - you can change the alias and the red message will go away.
I think the reason you are not seeing any reactions happen is that in your initial condition, no carbon is present - I only see nitrogen, oxygen and CO2
Try adding some carbon to the IC. It might also help to enable the stiff chemistry solver.
Hope this helps,
You have Carbon (you call it ash) in the solids phase.
The issue is the reaction rates depends on A-i which is not defined, so it is zero and DES_RATE is also zero. Note that you can also get garbage values if you don’t initialize a variable.
If you set a non-zero value for A_i it should work.
DES_RATES(Rx1) = (A_i*k_so*c_O2) / (ONE + K_H*p_O2 + KS*p_O2)
Sorry, indeed there is carbon in the solids phase, which I didn’t see. Thanks Jeff.
That’s it, thank you very much
That’s it, thank you very much!
