Please include project files - Main menu/Submit bug report - attach zip file here.
3D-fluidized-bed-geometry-model.mfx (10.5 KB)
How should i solve this problem.
3D-fluidized-bed-geometry-model.mfx (10.4 KB)
A few issues:
I made the changes in the attached.
Thank you for your reply. I have reviewed the example calculation carefully again. Is there a problem with the software permissions? This image shows that none of the mesh nodes can access the initial conditions or boundary conditions. Is it because the mesh file was not saved, which then caused it to be unreadable?
Default BC should be turned on in the file I sent. Do you see the check box checked?:
Thank you very much.The problem has been resolved.Your advise is very useful.
