Demtutorial3.tar (25.5 MB)
Hello, everyone.
I am a beginner. The edition I used is MFiX-20.4.2. I want to add one simple reaction following the tutorial case ‘silane_pyrolysis_pic_3d’:
‘SIH4–>SI+2H2’
I used the DEM model. Then, I modified the “usr_rates_des.f” (copy the content in the tutorial case). And I rebuild the solver through GUI rebuild button. Everything is fine EXCEPT nothing happened about the reaction. I tried to solve the problem for several weeks.
Could someone help me? Thanks very much!
There are a couple of issues:
- You turned off the call to UDFs. These must be on when you have chemistry. Go to the “model” pane and check the “Enable user-defined subroutines”
- Np, pM and IJK must be defined as integers in
usr_rates_des.f:
INTEGER, INTENT(IN) :: NP ! Global particle index
INTEGER, INTENT(IN) :: pM ! Particle solid phase
INTEGER, INTENT(IN) :: IJK ! Fluid Cell Index
You may want to use the equation of states for the gas density instead of constant density.
Thanks very much for your key guidance. The reaction happens.
Best regards!
Hi, Jeff. I am a Ph.D in geotechnical engineering. I find that MFiX is suitable for investing the dissolution mechanisms of methane hydrate.
Nevertheless, the stress state of the particle assembly is an important influential factor for geomechanics. So I wonder if your team could implement a servo-wall algorithm in DEM part of MFiX. I think it will promote the application of MFiX in a wider field.
