Dear developers,
In MFIX, when I use the MP-PIC method to calculate a staged fluidized bed containing gas-solid heat transfer, the results always diverge suddenly after a short period of time (about 0.2 seconds). I have attempted to improve the mesh and replace other heat transfer models ( by setting the des_conv_corr keyword,e.g. GNUU or WAKAO), but the problem still persists. However, if I remove the particles and calculate only the flow field, or if I set both the particle and fluid temperatures to 293.15k, which means that there is no temperature difference between the gas and the solid, both test cases appear to be able to calculate continuously. I have been struggling with this problem for quite some time. Could you please provide me with some advice on this issue? Is this non-convergence caused by grids or other heat transfer models?
Thank you so much!
staged-3-test_2022-09-26T065113.651059.zip (329.0 KB)
