Operating system error: Cannot allocate memory Allocation would exceed memory limit
Ready
Starting env OMP_NUM_THREADS=1 /home/koshal/anaconda3/envs/mfix-21.1.4/bin/mfixsolver -s -f /home/koshal/Documents/cyclone/cyclone.mfx
Invalid MIT-MAGIC-COOKIE-1 key
MFiX running: elapsed time 0:00:00
Number of SMP threads: 1
MFiX (21.1.4 ) simulation on host: KHOSHAL-PC
Run name: CYCLONE Time: 17: 2 Date: 5-28-2021
Project version: 10
Memory required: 9.00 Mb
INFO open_files.f:374
The following mesh file was not found: CYCLONE.msh
Mesh generation will be performed and a mesh file will be saved.
The following mesh file was successfully opened: CYCLONE.msh
From Get_Stl_Data: Analyzing BCs…
BC_ID BC_TYPE
4 CG_NSW
Number of CG BCs = 1
INFO cartesian_grid/get_stl_data.f:695
Reading geometry from geometry_0004.stl …
STL file opened. Starting reading data…
Done reading file.
STL file(s) successfully read.
Total number of facets read = 416
Number of valid facets = 414
Number of ignored facets = 2
Geometry range from stl file:
x-range = -16.1372 to -15.2438
y-range = 38.9455 to 40.0786
z-range = -2346.5161 to -2342.3640
The file FACETS_IGNORED.stl was successfully written.
and is provided for convenience (it is not used).
From Detect_stl_along_mfix_box:
Grouping facets by BC patch…
INFO cartesian_grid/get_stl_data.f:1656
Number of active facets (BCs not flush with MFiX box) = 414
The file FACETS_READ.stl was successfully written.
INFO check_data/check_solids_dem.f:712
At time = 0.000000E+00 sec., setting DEM solids time step, DTSOLID (sec) = 0.101800E-06
INFO check_data/check_geometry.f:192
DES grid size:
DESGRIDSEARCH_IMAX = 1193
DESGRIDSEARCH_JMAX = 1406
DESGRIDSEARCH_KMAX = 5413
WARNING check_data/check_boundary_conditions.f:151
Warning 1201: Mass inflow BC# 1
Cannot apply both mi and po to des. Turning off bc_po_apply_to_des.
WARNING check_data/check_boundary_conditions.f:180
Warning 1202: Pressure or Mass outflow BC# 2
Cannot apply both mi and po to des. Turning off bc_mi_apply_to_des.
Warning 1202: Pressure or Mass outflow BC# 3
RE-INDEXING IS TURNED OFF.
INITIALIZING VELOCITY NODES…
ESTIMATING POTENTIAL SCALAR CUT CELLS…
INTERSECTING GEOMETRY WITH U-MOMENTUM CELLS…
INTERSECTING GEOMETRY WITH V-MOMENTUM CELLS…
Error termination. Backtrace:
#0 0x7efc3608dd01 in ???
#1 0x7efc3608e849 in ???
#2 0x7efc3608eaa4 in ???
#3 0x7efc369a5a21 in __desgrid_MOD_desgrid_init
at /home/koshal/anaconda3/envs/mfix-21.1.4/share/mfix/src/model/des/desgrid_mod.f:802
#4 0x7efc367d7de4 in __main_MOD_check_data
at /home/koshal/Documents/cyclone/build/pymfix/main.f90:720
#5 0x7efc367d83d6 in _main_MOD_get_data
at /home/koshal/Documents/cyclone/build/pymfix/main.f90:585
#6 0x7efc36ad17d1 in run_mfix
at /home/koshal/anaconda3/envs/mfix-21.1.4/share/mfix/src/model/mfix.f:127
#7 0x7efc367d960e in __main_MOD_run_mfix0
at /home/koshal/Documents/cyclone/build/pymfix/main.f90:82
#8 0x7efc367bdc10 in f2py_rout_mfixsolver_main_run_mfix0
at /home/koshal/Documents/cyclone/build/f2pywrappers/mfixsolvermodule.c:1279
#9 0x7efc367dc396 in fortran_call
at /home/koshal/anaconda3/envs/mfix-21.1.4/lib/python3.7/site-packages/numpy/f2py/src/fortranobject.c:468
INTERSECTING GEOMETRY WITH W-MOMENTUM CELLS…
SETTING CUT CELL TREATMENT FLAGS…
COMPUTING INTERPOLATION FACTORS IN U-MOMENTUM CELLS…
COMPUTING INTERPOLATION FACTORS IN V-MOMENTUM CELLS…
COMPUTING INTERPOLATION FACTORS IN W-MOMENTUM CELLS…
COMPUTING 1/DX, 1/DY, 1/DZ FOR U-MOMENTUM CELLS…
COMPUTING 1/DX, 1/DY, 1/DZ FOR V-MOMENTUM CELLS…
COMPUTING 1/DX, 1/DY, 1/DZ FOR W-MOMENTUM CELLS…
FINDING MASTER CELLS FOR U-MOMENTUM CELLS…
FINDING MASTER CELLS FOR V-MOMENTUM CELLS…
FINDING MASTER CELLS FOR W-MOMENTUM CELLS…
MESH STATISTICS:
NUMBER OF CELLS = 1000
NUMBER OF STANDARD CELLS = 998 ( 99.80 % of Total)
NUMBER OF CUT CELLS = 0 ( 0.00 % of Total)
NUMBER OF FLUID CELLS = 998 ( 99.80 % of Total)
NUMBER OF BLOCKED CELLS = 2 ( 0.20 % of Total)
CARTESIAN GRID PRE-PROCESSING COMPLETED IN 0.16 SECONDS.
#10 0x559277c38c9a in _PyObject_FastCallKeywords
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:199
#11 0x559277c9e27d in call_function
at /tmp/build/80754af9/python_1614362349910/work/Python/ceval.c:4619
#12 0x559277c9e27d in _PyEval_EvalFrameDefault
at /tmp/build/80754af9/python_1614362349910/work/Python/ceval.c:3093
#13 0x559277c30e2a in function_code_fastcall
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:283
#14 0x559277c30e2a in _PyFunction_FastCallKeywords
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:408
#15 0x559277c996ef in call_function
at /tmp/build/80754af9/python_1614362349910/work/Python/ceval.c:4616
#16 0x559277c996ef in _PyEval_EvalFrameDefault
at /tmp/build/80754af9/python_1614362349910/work/Python/ceval.c:3110
#17 0x559277c30e2a in function_code_fastcall
#18 0x559277c30e2a in _PyFunction_FastCallKeywords
#19 0x559277c996ef in call_function
#20 0x559277c996ef in _PyEval_EvalFrameDefault
#21 0x559277be1d2a in function_code_fastcall
#22 0x559277be1d2a in _PyFunction_FastCallDict
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:322
#23 0x559277c007a2 in _PyObject_Call_Prepend
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:906
#24 0x559277bf33ad in PyObject_Call
at /tmp/build/80754af9/python_1614362349910/work/Objects/call.c:245
#25 0x559277cf1c16 in t_bootstrap
at /tmp/build/80754af9/python_1614362349910/work/Modules/_threadmodule.c:994
#26 0x559277cac667 in pythread_wrapper
at /tmp/build/80754af9/python_1614362349910/work/Python/thread_pthread.h:174
#27 0x7efc83f8a608 in start_thread
at /build/glibc-eX1tMB/glibc-2.31/nptl/pthread_create.c:477
#28 0x7efc83eb1292 in ???
#29 0xffffffffffffffff in ???
MFiX process has stopped
As the message says, you ran out of memory.
You need to either run on a machine with more available memory, or make your grid coarser to reduce the memory requirement.
This is alarming:
DES grid size:
This is about 9 Billions cells!! Please double check the particle size. The des grid is by default 3 times the particle diameter.
