Dear developer,
When I do parallel computing in Linux, MFiX-21.4 always reports the error(as follow) after a few seconds. I don’t know whether the calculation is divergent or other reasons.Could you guide me,thank you very much!
In addition, I would like to ask whether the solid outflow velocity at the mass outlet has an impact on the particle outflow per unit time.
corrupted size vs. prev_size
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
NITs/SEC = 26.93
Timestep walltime, DEM solver: 2.488 s
t= 2.000235 Wrote SPx: 1
,2
,3
,4,5
,6
,7,8,9;
.RES;
#0 0x7f064dc433ff in ???
#1 0x7f064dc4337f in ???
#2 0x7f064dc2ddb4 in ???
#3 0x7f064dc864e6 in ???
#4 0x7f064dc8d5eb in ???
#5 0x7f064dc8de45 in ???
#6 0x7f064dc8f27a in ???
#7 0x7f05ff0b65b3 in __write_res1_des_MOD_write_res_parray_1i
at /home/tong/anaconda3/envs/mfix-21.4/share/mfix/src/model/des/write_res1_des_mod.f:464
#8 0x7f05ff2c5936 in __write_res0_des_mod_MOD_write_res0_des
at /home/tong/anaconda3/envs/mfix-21.4/share/mfix/src/model/des/write_res0_des.f:54
#9 0x7f05ff110f54 in _output_man_MOD_output_manager
at /home/tong/anaconda3/envs/mfix-21.4/share/mfix/src/model/output_manager.f:162
#10 0x7f05ff0fde46 in run_mfix
at /home/tong/anaconda3/envs/mfix-21.4/share/mfix/src/model/mfix.f:166
#11 0x7f05fef34f32 in __main_MOD_run_mfix0
at /home/tong/mfix/continuous-moving-bed/build/pymfix/main.f90:81
#12 0x7f05fef29056 in f2py_rout_mfixsolver_main_run_mfix0
at /home/tong/mfix/continuous-moving-bed/build/f2pywrappers/mfixsolvermodule.c:1353
#13 0x55e6944ef540 in _PyObject_MakeTpCall
at /usr/local/src/conda/python-3.8.15/Objects/call.c:159
#14 0x55e6944eb373 in _PyObject_Vectorcall
at /usr/local/src/conda/python-3.8.15/Include/cpython/abstract.h:125
#15 0x55e6944eb373 in _PyObject_Vectorcall
at /usr/local/src/conda/python-3.8.15/Include/cpython/abstract.h:115
#16 0x55e6944eb373 in call_function
at /usr/local/src/conda/python-3.8.15/Python/ceval.c:4963
#17 0x55e6944eb373 in _PyEval_EvalFrameDefault
at /usr/local/src/conda/python-3.8.15/Python/ceval.c:3469
#18 0x55e6944f71d5 in PyEval_EvalFrameEx
at /usr/local/src/conda/python-3.8.15/Python/ceval.c:741
#19 0x55e6944f71d5 in function_code_fastcall
at /usr/local/src/conda/python-3.8.15/Objects/call.c:284
#20 0x55e6944f71d5 in _PyFunction_Vectorcall
at /usr/local/src/conda/python-3.8.15/Objects/call.c:411
#21 0x55e6944e6c84 in _PyObject_Vectorcall
at /usr/local/src/conda/python-3.8.15/Include/cpython/abstract.h:127
#22 0x55e6944e6c84 in call_function
#23 0x55e6944e6c84 in _PyEval_EvalFrameDefault
at /usr/local/src/conda/python-3.8.15/Python/ceval.c:3486
#24 0x55e6944f71d5 in PyEval_EvalFrameEx
#25 0x55e6944f71d5 in function_code_fastcall
#26 0x55e6944f71d5 in _PyFunction_Vectorcall
#27 0x55e6944e6c84 in _PyObject_Vectorcall
#28 0x55e6944e6c84 in call_function
#29 0x55e6944e6c84 in _PyEval_EvalFrameDefault
#30 0x55e6944f71d5 in PyEval_EvalFrameEx
#31 0x55e6944f71d5 in function_code_fastcall
#32 0x55e6944f71d5 in _PyFunction_Vectorcall
#33 0x55e69450695a in _PyObject_Vectorcall
#34 0x55e69450695a in method_vectorcall
at /usr/local/src/conda/python-3.8.15/Objects/classobject.c:67
#35 0x55e6945090a1 in PyVectorcall_Call
at /usr/local/src/conda/python-3.8.15/Objects/call.c:200
#36 0x55e6945090a1 in PyObject_Call
at /usr/local/src/conda/python-3.8.15/Objects/call.c:228
#37 0x55e6945dcc38 in t_bootstrap
at /usr/local/src/conda/python-3.8.15/Modules/_threadmodule.c:1002
#38 0x55e6945dcb83 in pythread_wrapper
at /usr/local/src/conda/python-3.8.15/Python/thread_pthread.h:232
#39 0x7f064e96b179 in ???
#40 0x7f064dd08dc2 in ???
#41 0xffffffffffffffff in ???
/home/tong/mfix/continuous-moving-bed/mfixsolver: 行 3: 3017370 已放弃 (核心已转储)env LD_PRELOAD=/usr/lib64/openmpi/lib/libmpi.so LD_LIBRARY_PATH=${LD_LIBRARY_PATH:+$LD_LIBRARY_PATH:}“” PYTHONPATH=“/home/tong/mfix/continuous-moving-bed”:“”:${PYTHONPATH:+:$PYTHONPATH} /home/tong/anaconda3/envs/mfix-21.4/bin/python3.8 -m mfixgui.pymfix “$@”
Process name: [[10150,1],10]
Exit code: 134
MFiX process has stopped
continuous-moving-bed_2023-03-09T173245.857125.zip (1.2 MB)
