Hello, I am working on case using DEM and SQP. However the particle orientation doesn’t changes as shows in this video below, looks as if particles are behaving just like spheres. I want to understand what am I doing wrong while defining the case. I want to study shear in non spherical particles.
I have also attached my case file. smooth_sphero.zip (46.9 MB)
Any help would be appricieted
You are using old modified versions of calc_collision_wall_mod.f and des_time_march.f that predate the SQP model. Please use the ones that come with the rotating drum dem tutorial instead.
Note, when I run this case - after updating calc_collision_wall_mod.f and des_time_march.f and rebuilding - I get a DT < DT_MIN. Recovery not possible! error at t=0.0489. I cannot reproduce your results.
Have you tried it? Change the model type in the “Model setup” pane and then define the particle in the “Solids” pane. You should be able to generate a GSP based on the same superquadric shape parameters. Please let us know if this succeeds, or if you come across some problems.
