I am simulating a case where the particle size is larger than the outlet size. To resolve the outlet, I had to make the mesh size smaller than the outlet size. This causes the mesh size to be much smaller than the particle size, and an error is reported. I learned that diffusion equations might be able to simulate this situation, but I didn’t know how to do it in mfix. Can I do this in the gui? Or what do I need to do in user-define subroutine to do that?
You can do it to some extent when the particle size is near the Eulerian grid size or a bit larger.
- Turn on interpolation (particle to field and field to particle)
- Use the square DPVM interpolation and set an interpolation width
- Turn on “Enable mean field diffusion” and set a diffusion width
- Turn on “Enable explicit coupling of interphase quantities”
Thanks, I will try that. My cell width is 1 mm and particle size is 3mm, not a bit larger…
Three times larger is quite a bit larger!!
