Particle size variation
Hello, about the simulation of gas-solid chemical reaction, I would like to ask how to set the particle size of solid particles does not change and the particle size changes with the progress of chemical reaction, where to set specifically, thank you!
https://mfix.netl.doe.gov/doc/mfix/22.2/html/model_setup/solids.html#solids-phase-material-properties
