I have a model of a hopper feeding grains into a box. The box is currently closed on all sides allowing a pile to form.
However now I want to put an outlet on one side of the box, so the particles drop into the box, form a pile, and some leave when the pile gets too large.
I have defined the region where I want the outlet to go, however I am unsure what the boundary condition should be for this. I do not want the particles to just roll out the box, but form a pile and only leave if pushed out. Could anybody help with this?
If you want particles to leave the domain, then it must be a pressure outlet BC. You may want to post a sketch of the geometry and BC locations.
I am assuming this is DEM. Is it a granular flow or coupled (gas+solids) flow?
Are you using an STL file?
Yes it is a DEM model of pure granular flow. I have attached the mfix file for this project.
rice_experiment.mfx (24.3 KB)
Couple of issues:
- Your box is made of overlapping walls. Your geometry should only represent the internal surface of the box.
- The box needs to be connected to the hopper.
This means you get a mesh that is not usable, even for a granular flow. You need to fix the above and probably refine the grid spacing to get a decent mesh.
I did not see where your want to put the outlet from your project file (the “Outlet” region is not a plane and is not used as a BC).
Something like this:
rice_experiment.mfx (14.6 KB)
rice_experiment.stl (248.7 KB)
Ok I understand, thank you
