I intend to add biomass particles with different particle sizes. My approach is to define 5 additional solid phase parameters, which are identical in all aspects except for the particle size, and their component settings are also the same. However, when I was editing the solver, the following error occurred:“processing chemical reaction data from 01.mfx; Error, duplicate entry for cellulose”
I suspect the root cause is that all these 5 solid phases contain the components of cellulose, char, and ash with identical naming conventions, thus triggering this duplicate entry error. Admittedly, I have considered renaming the components of the other phases as a workaround, but this would involve extensive modifications across the entire project. Therefore, I would like to ask if there is a simpler and more efficient method to resolve this issue.
