Hello everyone, I would like to know what impact not setting the maximum and minimum values will have when using PSD, or is it necessary to set this?
Secondly, if I use CGM with a statistical weight of 4, do I still need to adjust the parameters such as μ for my PSD, or does the software automatically adjust them.
If you don’t set the min and max, the distribution will include arbitrarily small and arbitrarily large particles (at a very small probability), since the Gaussian never goes completely to zero. You probably don’t want that. Tiny particles can be ignored, and very large particles probably don’t occur in the real world (there is typically some physical factor limiting the maximum particle size)
I’m not sure I understand your second question about μ.
Hello, my second question is if I use the CGP model with w=4, will the μ still be 0.0015m and will it still change.
The PSD is for the real particle size. The statistical weight will scale the entire PSD. If the real particle diameter mean is 0.0015m, then the coarse grained particle mean will be 0.0015*4^(1/3) ~ 0.0024m.
