I am modeling a simple thin solid surface for 10 particles to transfer heat onto. The goal is to obtain the temperatures from the surface as a result of contact with the higher temperature particles.
The model has an error within the first minute of the run due to DT<DT_MIN.
I received a few different warnings prior to the stop, but I believe it stems from the particles not being seeded
Warning 1202 The system is initiated with no particles and no solids inlet was detected.
and out of bound velocities. I have tested higher scale factors, but that also scales the velocities up to meet it.
Warning: velocity higher than maximum allowed velocity: 50.000 (to change this adjust the scale factor MAX_INLET_VEL_FAC)
Finally, the run stops with this error. I saw from previous forum posts that this may be a mesh error, however the imported stl is a prismatic plate, basically a box so I don’t image there is much complex meshing that would be generating errors.
Error from time_step.f:193
This is the first time I have posted on this forum, so if there is any additional information needed, please let me know what I can provide. Thank you!
100p_surfacemodeled.mfx (21.0 KB)
100P_SURFACEMODELED.msh (9.3 MB)
