hello developer, I am new user of mfix-22.4.1. I got problem how to run simulation with stl file. I am using windows.
please guide me how to solve this problem…
COBACOBA_FACETS_READ.stl (286.0 KB)
geometry.stl (183.7 KB)
here,
fluidized-bed.zip (133.2 KB)
complete file
Hi @Parman
There are two .mfx files in the ZIP file you uploaded. I assume the real project is cobacoba.mfx and the air-reactor file is a stray.
The error you posted regarding DES_ETAT_FAC is a warning, not a fatal error. You can make this go away by setting a value for this key, but it should be OK to leave it at the default.
When I run the case, I get a different error:
In file '/opt/conda/conda-bld/mfix-solver_1676050431375/work/model/des/mpi_init_des_mod.f', around line 183: Error allocating 39293975568 bytes: Cannot allocate memory
Error termination. Backtrace:
#0 mpi_init_des_MOD_desmpi_init
at /usr/local/src/conda/mfix-solver-22.4.2/model/des/mpi_init_des_mod.f:182
#1 main_MOD_check_data
at /usr/local/src/conda/mfix-solver-22.4.2/model/main.f:698
#2 main_MOD_check_data
at /usr/local/src/conda/mfix-solver-22.4.2/model/main.f:580
#3 main_MOD_get_data
at /usr/local/src/conda/mfix-solver-22.4.2/model/main.f:562
#4 run_mfix
at /usr/local/src/conda/mfix-solver-22.4.2/model/mfix.f:127
#5 main_MOD_run_mfix0
at /usr/local/src/conda/mfix-solver-22.4.2/model/main.f:79
I will follow up on this.
This is not a case you can run with DEM. With a particle size of 2 microns, the estimated number of particles is around 1E16 !!
MFiX is running out of memory because the DEM grid is too large:
DES grid size:
DESGRIDSEARCH_IMAX = 100000
DESGRIDSEARCH_JMAX = 746500
DESGRIDSEARCH_KMAX = 100000
I think you will need to switch to TFM. PIC and CG-DEM are probably out of reach as well.
You also don’t need both sides of the wall in your stl file. Only the internal geometry is needed.
thanks for your suggestion
doesn’t it mean the problem form stl import file ? actually, I am hopeless to the stl file due to never give I result and never run as well.
The primary issue is you have way too many particles for a DEM simulation and you run out of memory. That’s why it doesn’t run. Please take a look at existing tutorials to see examples of DEM simulations and how to set the geometry.
Dear Mr Jeff
please help me why my 3D model stl file like this…
Dear Mr Jeff
I am sincerely ask…if it’s possible, please run my model with any input and give me running model for the stl file.
best regards
Parman
@cgw please help me this issues
Dear Mr @cgw
best regards
Parman
Please be patient and remember the forum is open to all MFiX users, so anyone is encouraged to help.
A few things:
thank you @jeff.dietiker for your valuable suggestion
hiiii,
sorry for the disturbance. i encountered similar problems with you, but i really don’t know how to include the interior wall only in stl file, could you please kindly share some experience with me?
Really looking forward to your reply!!!
This is not done in MFiX but in the CAD software you used to create the STL.
Including only what I call the interior wall is the typical way we think of the geometry with CFD. We are modeling the fluid region, and this fluid region is bounded by boundaries along which we apply boundary conditions. The stl geometry defines these boundaries, i.e. surfaces where the fluid and solid are in contact. The STL geometry does not represent the solid volume around the fluid region. Imagine the solid is a mold and you pour wax into the mold. After the wax hardens, you have 2 objects: the mold and the wax object. The STL geometry should be that of the wax object, not the mold. The normal vectors should point towards the fluid region.
The link below will show you an example of a cyclone geometry:
https://mfix.netl.doe.gov/doc/mfix/22.4/html/_downloads/31aace55879e30267f1693223d65a44c/cyclone.stl
I hope this helps.
