Hello all, please see attached my mfix DAT file for the DEM simulation with the above mentioned error. Please also the “out-mfix” file for backtrace of this error. My simulation domain is a simple rectangular domain 100mm x 2mm x 1mm. The inlet is 2 sq. mm and 20% particle volume fraction at inlet, with 5 mm/s velocity.
The total number of particles coming in per second through the inlet is 3819. The simulation failed at 1.5142 s – I think it crashed because the total number of particles at that instant was more than what the domain could accommodate. Do I just increase the domain size to circumvent this? Or can a flag be inserted in MFiX source code to check for overflow of particles? Thanks
MFIX.zip (543.8 KB)
Please try with the latest version (19.1.4) and let us know if you get the same issue.
