Hey all,
I have a case which runs to completion at atmospheric pressure, in both serial and parallel, just fine. When I try to run this case at low pressures, the serial computation runs to completion but the parallel simulation can’t make it past the first time step (see Serial vs Parallel.zip (215.0 KB)). It seems like the first time step has very high y-velocity residuals “V0” that decrease substantially by the second time step (from ~1 → 0.0001).
It doesn’t seem like I can patch the gas phase initial condition using the results from the serial simulation, so I don’t really know how to get around this. I also don’t understand why only the parallel simulation has this convergence issue.
Let me know your thoughts! I omitted some text in the serial output log file to make the file size smaller, the first time step successfully converges at line 231.
