Simulation terminated almost immediately
Hello all,
I tried to run a simulation of adsorption and desorption at the same time. However, the simulation kept terminating right after I started them with this error. Is it complaining that some reaction is too fast or some number is too small? How do I interpret it so that I can figure out which part of the simulation is causing the problem? Thanks!
td_jelly_roll (7).mfx (21.7 KB)
usr_rates (12).f (3.0 KB)
Backtrace for this error:
#0 0x14c78fd61b4f in ???
#1 0x402e6f in usr_rates_
at /projectnb/ryanlab/jackz/test/AdDe50C/0.08249/usr_rates.f:88
#2 0x53748e in rrates0
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/rrates0.f:181
#3 0x414896 in __calc_coeff_mod_MOD_calc_rrate
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/calc_coeff.f:394
#4 0x414c27 in __calc_coeff_mod_MOD_calc_rrate
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/calc_coeff.f:385
#5 0x414c27 in __calc_coeff_mod_MOD_calc_coeff_all
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/calc_coeff.f:282
#6 0x40ce5f in _step_MOD_time_step_init
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/time_step.f:89
#7 0x403586 in run_fluid
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/mfix.f:186
#8 0x403586 in run_mfix
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/mfix.f:145
#9 0x403c89 in mfix
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/mfix.f:323
#10 0x402cb0 in main
at /projectnb/ryanlab/jack7z/.conda/envs/mfix-23.3/share/mfix/src/model/mfix.f:293
mpirun noticed that process rank 16 with PID 0 on node scc-yj3 exited on signal 8 (Floating point exception).
Bumping up my questions above. Also I tried setting the second reaction rate to 0, so it’s equivalent to having only 1 reaction. With only reaction 1 the simulation ran just fine, but adding a second reaction with 0 reaction rate produced the “Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation” error again. Does anyone know what might be the cause? Thanks! I attached my code below.
usr_rates (13).f (3.0 KB)
I am not able to reproduce with the files you attached. However, on line 88 of usr_rates.f , you are using c_CO2, which is not defined if x_CO2 is zero (or less than c_Limiter). You may most of the time get this value set to zero but you can also get some garbage value (You can add a print statement above line 88 to check). You either need to set c_CO2=0.0 when X_s(IJK, 1,ML) <= c_Limiter or always compute c_CO2.
Thanks Jeff! I revised line 88 and added an else statement that sets the c_CO2 concentration to 0 if x_CO2 is smaller than the limit.
Now I got the code to run with 0 reaction rate for reaction 2. But when I had non-zero reaction rate, it would still terminate after simulating several seconds of the reactions and give me the error “Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.”
Is there a way to see what’s causing the erroneous arithmetic operation? Thanks!
You should get a backtrace of where the error is occurring similar to what you posted at the top. You can also build the solver with debug flags (select “Debug” in the build type).
Thank you Jeff! I found the line that causing problem was
at /projectnb/ryanlab/jackz/test/AdDe50C/_0.10029/usr_rates.f:91
That line said
IF(c_ML > c_limiter) then
RATES(Reaction_1) =kc_CO2c_ML**2
I guess it ran into problem because c_CO2 is 0? But I thought if a reaction rate is 0 the reaction would just not happen. Why is there an erroneous arithmetic operation?
I pasted the full error below as well. Also how to run the debug mode in terminal? What command line would I use?
Thank you so much for your help!
#0 0x152602468b4f in ???
at /projectnb/ryanlab/jackz/test/AdDe50C/0.10029/usr_rates.f:91
#2 0x53749e in rrates0
#3 0x4148a6 in __calc_coeff_mod_MOD_calc_rrate
#4 0x414c37 in __calc_coeff_mod_MOD_calc_rrate
#5 0x414c37 in __calc_coeff_mod_MOD_calc_coeff_all
#6 0x40ce6f in _step_MOD_time_step_init
#7 0x403596 in run_fluid
#8 0x403596 in run_mfix
#9 0x403c99 in mfix
I think you may have the same problem with c_ML which is not defined if the molar concentration of microlith is below the c_limiter threshold. It is best to make sure all variables are initialized to avoid unexpected results. You are also using c_RM but it is not defined.
Once you build with debug flags, you can use the custom solver and it will generally provide more information when it fails. This is not a debugging tool per se, (you can’t pause, nor inspect variables).
