Hello everyone,
I am currently working on a Two-Fluid Model simulation of a fluidized bed. The geometry includes perforated distributor plates that should allow gas to flow through while preventing the bed material (solids phase) from passing through.
I have modeled these plates using semipermeable internal surfaces, with a very high fluid permeability, a resistance coefficient calculated from experimental pressure-drop measurements, and zero solids velocity. However, the solids pass through the plates as if the internal surfaces were not there.
I have attached my simulation files for reference.
Has anyone experienced similar behavior with semipermeable internal surfaces in TFM simulations? Are there any particular settings, mesh considerations, or boundary conditions that could cause MFiX not to enforce the prescribed zero solids velocity?
Any suggestions would be greatly appreciated.
Thank you in advance for your help!
SimpleFB.zip (25.4 MB)
