Dear MFIX development group,
I have noticed that some typos exist in the tutorials of MFIX 19.2.2. They are listed as follows.
4.11.4. Monitor Types
The table below summarizes the nomenclature used yo describe the monitor operators:
4.5.1. Fluid Model Options
Solve Species Equations By default, species transport equations are not solved for the fluid phase. If species equations are enabled, species will need to be added to the fluid phase using the fluid species tool. ADD REF
5.3.2. Building Solver from Source
For prerequisites, see Install Solver Build Dependencies (optional) or Install Solver Build Dependencies (optional).
5.3.3. Building Conda package
To build the conda package of MFiX, you will need to install the build dependencies for your platform. Please see Install Solver Build Dependencies (optional) or Install Solver Build Dependencies (optional).
6.2.2. Running Custom Solver From Command Line
On Windows, the current directory always takes priority for commands, so . is not needed.
8.2. User-Defined Functions
To activate the calls to the following three routines, make sure the “Enable user-defined subroutines” checkbox is checked in the Model pane.
8.4.13. How to manually specify a grid partition for DMP runs?
When running a simulation in parallel (DMP) mode, the parallel decomposition is by default uniform in each direction and the number of partitons is set by NODESI, NODESJ, and NODESK in the x,y and z directions, respectivelly. The default partition may not always be the most efficient. For example, a DEM simulation of a fluidized bed where most particles are at the bottom of the bed may run faster if smaller partitions are set at the bottom, where many particles are located and a large partition is used in the freeboard. This will better distribute particles amon processors, and provide a better load balance.
This means 8 cores will remain mostly iddle with respect to particle tracking and collision.
PS: some hyperlinks need to add and/or update.
8.1.3.2. Geometry
8.1.3.3. Mesh
8.1.3.4. Regions
8.4.1. How do I ask question, or send feedback?
Please send specific questions and feedback regarding the GUI to the support forum<https://mfix.netl.doe.gov/forum>__. Please include your version info in all communications (File Menu –> About and press the “Copy Version Info” button). Other technical questions regarding MFiX can be sent to the support forum<https://mfix.netl.doe.gov/forum>__.
Let’s make MFIX better.
Best wishes,
Robert Yu
