solar_03_2022-08-09T013222.922157.zip (200.4 KB)
`Dear developers,
something wrongs happened when I use dmp solver to run my project
BUG REPORT
Type of issue
solver crash
Description
When I use dmp solver to run my project,there are some wrongs:
Backtrace for this error:
Could not print backtrace:
unrecognized DWARF version in .debug_info at 6
Could not print backtrace: unrecognized DWARF version in .debug_info at 6
#0 0x7f26e9ee82ed in ???
#1 0x7f26e9ee7503 in ???
#2 0x7f273780af0f in ???
#3 0x7f26ca646a1f in ???
#4 0x7f26ca5f92d2 in ???
#5 0x7f26ca5f532a in ???
#6 0x7f26ca72cb0d in ???
#7 0x7f273706f4c2 in ???
#8 0x7f2737066910 in ???
#9 0x7f273705f020 in ???
#10 0x7f26cc7bf63a in ???
#11 0x7f27375581dd in ???
#12 0x7f27387d027d in ???
#13 0x7f27387f12aa in ???
#14 0x7f26ea2f0967 in ???
#15 0x7f26ea599f08 in __parallel_mpi_MOD_parallel_init
at /home/u/solar_03_2022-07-14T094752.541719/build/pymfix/parallel_mpi_mod.f90:46
#16 0x7f26ea58c2f9 in f2py_rout_mfixsolver_parallel_mpi_parallel_init
at /home/u/solar_03_2022-07-14T094752.541719/build/f2pywrappers/mfixsolvermodule.c:1827
#0 0x7fcf7588e2ed in ???
#1 0x7fcf7588d503 in ???
#2 0x7fcfc31b0f0f in ???
#3 0x7fcf55feca1f in ???
#4 0x7fcf55f9f2d2 in ???
#5 0x7fcf55f9b32a in ???
#6 0x7fcf560d2b0d in ???
#7 0x7fcfc2a154c2 in ???
#8 0x7fcfc2a0c910 in ???
#9 0x7fcfc2a05020 in ???
#10 0x7fcf5816563a in ???
#11 0x7fcfc2efe1dd in ???
#12 0x7fcfc417627d in ???
#13 0x7fcfc41972aa in ???
#14 0x7fcf75c96967 in ???
#15 0x7fcf75f3ff08 in __parallel_mpi_MOD_parallel_init
#16 0x7fcf75f322f9 in f2py_rout_mfixsolver_parallel_mpi_parallel_init
#0 0x7f6f544392ed in ???
#1 0x7f6f54438503 in ???
#2 0x7f6fa1d62f0f in ???
#3 0x7f6f34b97a1f in ???
#4 0x7f6f34b4a2d2 in ???
#5 0x7f6f34b4632a in ???
#6 0x7f6f34c7db0d in ???
#7 0x7f6fa15c74c2 in ???
#8 0x7f6fa15be910 in ???
#9 0x7f6fa15b7020 in ???
#10 0x7f6f36d1063a in ???
#11 0x7f6fa1ab01dd in ???
#12 0x7f6fa2d2827d in ???
#13 0x7f6fa2d492aa in ???
#14 0x7f6f54841967 in ???
#15 0x7f6f54aeaf08 in __parallel_mpi_MOD_parallel_init
#16 0x7f6f54add2f9 in f2py_rout_mfixsolver_parallel_mpi_parallel_init
#0 0x7f2d3eec22ed in ???
#1 0x7f2d3eec1503 in ???
#2 0x7f2d8c7e4f0f in ???
#3 0x7f2d1b508a1f in ???
#4 0x7f2d1b4bb2d2 in ???
#5 0x7f2d1b4b732a in ???
#6 0x7f2d1b5eeb0d in ???
#7 0x7f2d8c0494c2 in ???
#8 0x7f2d8c040910 in ???
#9 0x7f2d8c039020 in ???
#10 0x7f2d2179963a in ???
#11 0x7f2d8c5321dd in ???
#12 0x7f2d8d7aa27d in ???
#13 0x7f2d8d7cb2aa in ???
#14 0x7f2d3f2ca967 in ???
#15 0x7f2d3f573f08 in __parallel_mpi_MOD_parallel_init
#16 0x7f2d3f5662f9 in f2py_rout_mfixsolver_parallel_mpi_parallel_init
#17 0x560e748d7707 in ???
at /usr/local/src/conda/python-3.10.5/Objects/call.c:215
#18 0x560e748d3216 in ???
at /usr/local/src/conda/python-3.10.5/Include/cpython/abstract.h:112
#19 0x560e748de84e in ???
at /usr/local/src/conda/python-3.10.5/Include/internal/pycore_ceval.h:46
#20 0x560e748ce0bc in ???
at /usr/local/src/conda/python-3.10.5/Include/cpython/abstract.h:114
#21 0x560e74983521 in ???
#22 0x560e74983466 in ???
at /usr/local/src/conda/python-3.10.5/Python/ceval.c:1134
#23 0x560e7498a62e in ???
at /usr/local/src/conda/python-3.10.5/Python/bltinmodule.c:1056
#24 0x560e748dea40 in ???
at /usr/local/src/conda/python-3.10.5/Objects/methodobject.c:430
#25 0x560e748ce0bc in ???
#26 0x560e748de84e in ???
#27 0x560e748ce0bc in ???
#28 0x560e748de84e in ???
#29 0x560e749a843a in ???
at /usr/local/src/conda/python-3.10.5/Modules/main.c:297
#30 0x560e749a7d70 in ???
at /usr/local/src/conda/python-3.10.5/Modules/main.c:585
#31 0x560e749767a8 in ???
at /usr/local/src/conda/python-3.10.5/Modules/main.c:1090
#32 0x7f27377edc86 in ???
#33 0x560e749766b0 in ???
#17 0x55b4328e2707 in ???
#18 0x55b4328de216 in ???
#19 0x55b4328e984e in ???
#20 0x55b4328d90bc in ???
#21 0x55b43298e521 in ???
#22 0x55b43298e466 in ???
#23 0x55b43299562e in ???
#24 0x55b4328e9a40 in ???
#25 0x55b4328d90bc in ???
#26 0x55b4328e984e in ???
#27 0x55b4328d90bc in ???
#28 0x55b4328e984e in ???
#29 0x55b4329b343a in ???
#30 0x55b4329b2d70 in ???
#31 0x55b4329817a8 in ???
#32 0x7f6fa1d45c86 in ???
#33 0x55b4329816b0 in ???
#17 0x55f5a193e707 in ???
#18 0x55f5a193a216 in ???
#19 0x55f5a194584e in ???
#20 0x55f5a19350bc in ???
#21 0x55f5a19ea521 in ???
#22 0x55f5a19ea466 in ???
#23 0x55f5a19f162e in ???
#24 0x55f5a1945a40 in ???
#25 0x55f5a19350bc in ???
#26 0x55f5a194584e in ???
#27 0x55f5a19350bc in ???
#28 0x55f5a194584e in ???
#29 0x55f5a1a0f43a in ???
#17 0x55f04c7f5707 in ???
#18 0x55f04c7f1216 in ???
#19 0x55f04c7fc84e in ???
#20 0x55f04c7ec0bc in ???
#21 0x55f04c8a1521 in ???
#22 0x55f04c8a1466 in ???
#23 0x55f04c8a862e in ???
#24 0x55f04c7fca40 in ???
#25 0x55f04c7ec0bc in ???
#26 0x55f04c7fc84e in ???
#27 0x55f04c7ec0bc in ???
#28 0x55f04c7fc84e in ???
#29 0x55f04c8c643a in ???
#30 0x55f04c8c5d70 in ???
#31 0x55f04c8947a8 in ???
#32 0x7f2d8c7c7c86 in ???
#33 0x55f04c8946b0 in ???
#30 0x55f5a1a0ed70 in ???
#31 0x55f5a19dd7a8 in ???
#32 0x7fcfc3193c86 in ???
#33 0x55f5a19dd6b0 in ???
Floating point exception (core dumped)
a non-zero exit code… Per user-direction, the job has been aborted.
Process name: [[44245,1],2]
Exit code: 136
I don’t know why these wrongs happened,and I don’t know how to solve these wrongs.I have modified some codes to achieve my goal,but it run well without dmp solver.I support my bug report.
Thank you very much!
