I think that there is a bug with the Guo-Boyce TFM model. When taking the original .mfx file from the paper (located at GitHub - guoq52ce/MFiX-TFM-frictional-solids-stress-model-by-GZPXKB: Necessary udfs bulit into MFiX for a new frictional solids stress model that can capture structured bubbling in fluidized beds with vertical vibration or gas flow oscillation) and running it using MFiX-21.2 (as in the paper), the structuring looks very different to if you use MFiX-25.3 (most recent version) and run it using the Guo-Boyce model. Further, if you then use the UDF’s given by Qiang in the Github with MFiX-25.3, you get very similar structuring to what is presented in the PNAS paper (https://www.pnas.org/doi/10.1073/pnas.2108647118). Note - I have not made any other changes to the .mfx files, except remove some keywords that became depreciated during this time.
I think that this suggests that there is something wrong with the implementation of the Guo-Boyce model. I have attached an image showing the change in structure for the different cases: MFiX-21.2 with Qiang’s UDF showing structured bubbling, MFiX-25.3 with Qiang’s UDF showing structured bubbling, and MFiX-25.3 with Guo-Boyce model showing no structured bubbling.
All files are uploaded in the attached .zip - any help would be greatly appreciated!
Oscar
TFM_GuoBoyce_Bug.zip (876.8 KB)
