TFM Spouted bed with chemical reactions
Hello, I’m kinda new using this software, I’m trying to simulate a spouted bed with chemical reactions, initially, the simulation diverges at 0 seconds with message: DT<DT_min, after that i change Small Cell Tollerance and Snap tollerance from the mesher and now the simulation is running. My confussion is, now the Time Remaing is 16 hrs, is that a good signal? I mean, other tutorials does’t take that much time and my geometry isn’t that complex. Can you take a look and see if something is wrong?
Ty for your time
sichemkin_2026-08-26T171631.266725.zip (866.1 KB)
After 30 minutes I get the message DT<DT_MIN again, at 0.04 second of simulation VTK.
Does it run fine if you turn off the reactions?
Yes, I have another file where i try the BC, IC without any species nor chemical reactions, it runs fine, the species that im using are the specified in the tutorial from biomass gasification
