HI DEAR ALL,
I run the DMP version of CFD-DEM of mfix-19.1.0. The below error appeared frequently. Then I have to restart the .exe to keep the calculation. Anybody knows the root reason? Thank you.
I use a cluster with CentOS release 6.6.
A few suggestions:
- Check all log files and job output files to see if there are any useful information.
- Build the solver in debug mode (see examples at 5.3. Build from Source (for Developers) — MFiX 19.3.0 documentation) and run again. This may produce more informative error messages.
- It may be worth updating to 19.3
Hi Jeff,
Thank you for your response. I checked this problem throughout internet. I found one way worked for me: to increase the core number for the calculation. Thanks again.
Best,
Leina
Hi Jeff! If a job running in DMP using the cluster is terminated, how can I restart the job and keep computing?
