The mass inlet shows a simulated error. How should I resolve this issue?
I want to inject particles from the pipeline, but after setting the parameters and interface, I still cannot solve this problem. I have also tried other methods, but the simulation can run while the particles are not generated or injected.As shown in the figure, the red represents the mass inlet conditions, and the cylinder represents the no-slip confined boundary conditions. I hope to get some help, thank you all.
I will also upload the file below.
519.zip (2.6 MB)
I don’t know the reason, but the uploaded images and videos cannot be displayed.
what are the file types, names and sizes of the files you are trying to upload?
I am not able to load the attached setup. There is an issue on my system with the STL file names, which are in Chinese characters (stored as unicode in the mfx file). There are references to 3 stl files (搅拌桨.stl for the mixing blade, 反应釜.stl for the reactor and 导入筒.stl for the cylinder). I only see 导入筒.stl.
There are also 3 zip files inside the 519.zip which is confusing. Please create a new project directory (looks like all files are saved on your desktop, which is not ideal) and rename your stl files. I suggest:
搅拌桨.stl → mixing_blade.stl
反应釜.stl → reactor.stl
导入筒.stl → cylinder.stl
Then go to the main menu>submit bug report to generate the zip file and attach it.
